Would i be better off...
AZ
I am wanting to get an LST, but i have heard soo many bad things about that mach .26. Theres the washer problem, now i'm hearing things about the con rods! I would just get a new engine, but since the LST is freakin 600 bucks, i wont have any extra cash after the purchase. Am i better off with a REVO?
YT, BOTSWANA
RE: Would i be better off...
Revo RULZ!!!!
ORIGINAL: NitroRulz23
AZ
ORIGINAL: ThermalRD
Revo RULZ!!!!
Revo RULZ!!!!
1)you can take the waher off the motor.
2)there are problems with the car, just like every car.
3)revo rocks, but get the lst.
4)havent you already made a thread about this?
AZ
ORIGINAL: alex7
AZ
ORIGINAL: alex7
ok, but i thought you were staying with your t-maxx.
AZ
ORIGINAL: alex7
ohhthen get the lst.
AZ
ORIGINAL: alex7
i didnt meant to offense you, just that i thought you were staying ONLY with your maxx
well theres always some problem in any car, i think with the lst thats the problem.
if you are getting the lst, get this, secondary gear cover, aluminum diff case, new arms, and you are ready to go
p.s.didnt ment to offend you with the icon.
AZ
ORIGINAL: alex7
well my brother another batteries for his lst, i dont have the exact link, but you can get them here:
http://www.onlybatteries.com/
CA
i have a 5 cell hump pack under the gas tank. it fits. Only thing is if you wanna go to a higher capacity tank you will have to throw out the hump and get a flat pack and put that under the chassis.
ORIGINAL: TheHamburglar
ahhh, ok. I need to go put some money down on an LST so i will stop freakin changing my mind! but what about this con rod problem? should i be worried?
Don't worry about it. If (and that's a big IF) you have an engine problem, Losi and/or Horizon will be more than willing to replace it for you.
That pack that you linked will fit under the fuel tank with a little elbow grease.
yeah, dont worry about the conrod problem, as jefx said horizon will replace the engine in case that happens, i bought my lst knowing the problems that it has breaking conrods and i know that if that happens horizon will replace it because its not my fault, its a factory defect. i live in bolivia so i am still thinking of what i am going to do if my engine conrod breaks, hopefully horizon will tell me to send it directly from here and if they say that they cant accept that, then i will search for another solution.
go fot it, you wont be disappointed
by the way alex7 is my brother
