MY NEW CLOD!!! WITH PICS!!
Hey everyone, look at my new clod i just won on ebay!!!!
I am thinking of getting some imex baja tires as my first upgrade..what else should be upgraded to make it a good basher?
i am going to be running a stock motor in it for starters and upgrade to a qm19t later on with some gp3300's
I have one question...acutally 3...
1. where do i mount the motor(singular)
2. ive herd you can run 2 motors, this true?
3. where do i mount the second motor if i were to get az compatable ESC?
RE: MY NEW CLOD!!! WITH PICS!!
The Clodbuster is designed to have two motors
Have a look at the black plastic Differential Housings (Front and rear solid axles) You will see a place to mount the motors. The motors actually get bolted directly to the Diff Housings. So Yeah, you need two motors. The clodbuster is also designed for 4-wheel steering, but you can fix the rear wheels so they don't turn if you like... but 4WS makes it a LOT easier to rock crawl with.
Nice looking Cloddy by the way [8D]
i dono, i litteraly just won it 1 hr ago on ebay, i need to send out the MO tomarrow and wait for it to show up here
can anyone answer my question?!
ORIGINAL: SirAIGman
so i cant run it off one motor for the time being? and what dual motor'd esc is there other than the EVX from traxxas?
I see the emaxx 550 motors for sale once ina while on ebay, why not start with a set of those?
ON, CANADA
ORIGINAL: SirAIGman
ok..im a newbie to cloddies. how do i use the superrooster with 2 motors..i only have a 2 channel radio, but i can use my fathers 3 channel for 4ws. i need to know how much mopney its going to cost me to get it to run 2 motors? and i am assuming i need 2 batteries at the same time?
If you use one of these you can get away with 4 wheel steering with a 2 channel radio:
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXAFN2
Not sure about super modified clods like yours, but the stock setup uses one servo for both front and read steering. 2 channels, 2 servos, 2 motors. A standard ESC will be fine unless you put bigger motors in.
PA
There is no problem with you running just one motor, but it does kind of defeat the purpose of such a truck. You might want to cover the hole in the front axle if you do this to keep pebbles from jumping in there.
That clod has a different steering setup than a stock clod. It should have mounts to allow you to mount a servo in the front and rear, but its possible the previous owner has it setup for just two wheel steering. Then to run the two servos you just need a "Y" lead. You can then use a standard 2 channel radio.
My Feedback: (18)
Just so you know, the Emaxx motors (or any 550's for that matter) wont work with a clod that uses the Tremor or Ripper chassis. The motor cans are too long and will hit on the lower links.
I was going to put them in mine untill I found out they wouldn't fit.
