XTM Mammoth ST
IL
XTM Mammoth ST
Upon breaking in, starting for the first time, we did not see fuel in the Mammoth ST's lines and flooded the engine while priming it. (All happened while going directly from instruction booklet) We fixed the flooding and realized that my glow starter was dead. We removed the fuel tank and dumped the excess fuel back into the quart. There are little bubbles of fuels inside the lines, is this a problem? If there is any fuel residue in the enigine that isn't visible, is that a problem too? THanks!
GA
RE: XTM Mammoth ST
First ,take a relaxing breath of air................... , alright while relaxed remove glow plug and turn truck upside down, then upriht it and put glow plug back in snug , then back it out 1/2 turn so air can escape out glow plug hole if flodded. While glow plug is out 1/2 turn put glow plug starter with good batteries in it on the glow plug and pull the cord. Use quick short snaps of the pull cord, only pulling out maybe 6 or so inches of cord. If it doesn't crank in about 10 pulls REMOVE glow starter and put your finger over the exhaust hole and pull cord until fuel just barely reaches carburator( called priming). Then put glow starter back on and pull until it cranks. If still no go, tighten glow plug and prime again, put glow starter on and pull cord.
If this doesn't work check your needle settings with factory specs to be sure your carb isn't out of wack ( technical term), or go to Global hobbies forum for XTM help.
Hope this helps.... and remember , patience is precisious in a situation like this. It is easy to get mad a sell it for scrap , so remember me when you want to give it to someone for merely shipping costs alone, I'll be happy to give it a good home
Joe
Joe
GA
RE: XTM Mammoth ST
Oh yea, check out the upgrades you can do for your XTM ST.
Chassis braces
Hi Tech 945MG steering servo
alum lower a arms
big ol fuel tank
alum servo saver
NIMH receiver batts w/ charger cord
come to think of it, I have spent more on upgrades than the truck to start with[]
Joe
Chassis braces
alum lower a arms
big ol fuel tank
alum servo saver
Joe
MI
RE: XTM Mammoth ST
Also from what I hear on the global site, it would be wise to put some shims in the diffs.; both front and rear.
Hey REVO, how do you like the brakes on the ST? Just curious!
GA
RE: XTM Mammoth ST
Hey,
The brakes on my ST are the best of any of my trucks. Flat lock em up on bout any surface. It is a fine line to get em perfect ,chance of too close and rubbing ,and throttle trim will upset the adjustment if I'm not careful, but none the less , the best brakes of my fleet.
Why do you ask?????? , I just reassembled the truck today from just about an empty chassis, thought you saw something in my pic that was hooked up backwards or something, as it has not been run since the rebuild ( added chassis braces this weekend). Knowing my state of mind working with a 3 year old at my heels it would not surprise me if I forgot to install the linkage or something
Joe
Joe
IL
RE: XTM Mammoth ST
My problem is the XTM glow starter, the thing won't charge. No directions came with it from Hobby People. Check out my XTM Glow Starter post in RC Car General Discussions. When I get the glow plug working, then I'll be able to break it in.
MI
RE: XTM Mammoth ST
Nothing wrong from what I can see in the pics! I cant get these brakes to do squat! They are just enough to slow me down! I'm not new to this kinda stuff but man I just cant seem to get these things to work!! I was supposed to head up to the track today and let BT take a look at it but I dont know if time will allow it!!
GA
RE: XTM Mammoth ST
Come to think of it, my brakes may have gotten much better when I put in a 6v. rechargable receiver pack in it. Maybe it's just to much for the 4.8v. alkalines that come stock?
JOe
JOe
ID
RE: XTM Mammoth ST
so does ever one here like the mammoth st is it strong and fast you now that kind of stuff. im a racer and i think im going to buy a new truck and would like to now if i would be going wrong with this truck or not.
RE: XTM Mammoth ST
My mammoth is being really retarded. The guy i bought it from was kinda creepy and was always like how do you "prime you engine" he didnt tell us much about the truck either just said put out finger over the carborator then pull, well wrong he was we pulled the string comes out for the pull start!!!!. It took us so long just to start the thing, were is electirc start??
Is it alot easier to start after you get it broken in???
I think i will take some of the advice from some of you guys about starting it because mine would always air lock so do a half turn with the glow plug???
RE: XTM Mammoth ST
ORIGINAL: kolester9
CA
RE: XTM Mammoth ST
The electric start thats made for it is a [link=http://xtm-dealer.com/zencart/index.php?main_page=product_info&cPath=13&products_id=180]Sure Start[/link] and it works quite well. As far as the starting is concerned nothing could be farther from the right way to start it than put your finger over the carb [&:] a drop of fuel or with the electric start finger over the exhaust pipe till fluid gets up to the carb [:-] when set up right that SH engine is easier than most to start and run
RE: XTM Mammoth ST
My mammoth doesnt seem to click into second and it sure aint going fast is it jsut tuning or is there jsut something wrong with the engine you think?
RE: XTM Mammoth ST
ORIGINAL: kolester9
RE: XTM Mammoth ST
ORIGINAL: kolester9
And where would this shift point be located to adjust it? And How should i adjust it?
CA
RE: XTM Mammoth ST
Well darn, had to dig this old thread up because of the new kid on the block thats taking over for the Mammoth st.........................hope it brings back the flair that the old Mammoth had,and it just might [link=http://www.xtm-dealer.com/Truggy.html]X st[/link]
