What clutch will fit a XTM 24.7 MOTOR for my X-factor 2
Banned
My Feedback: (7)
TX
the clutch in my x factor doesnt work until its warmed up so ive finally broke down and decided to buy a upgraded clutch kit for it, what clutches will fit, i just dont want to buy a clutch for 30-40 bucks and it not work, a link would be awesome, thanks josh
RE: What clutch will fit a XTM 24.7 MOTOR for my X-factor 2
I had an XTM 24.7 in my Savage, I upgraded to the Mugen aluminum shoes and 1mm springs... It was a direct replacement with no mods necessary.
I LOVED this setup, because it let the engine rev a little more before the shoes grabbed the clutch bell. The takeoff was phenomenal! Increased the tranny stall by like 3,000 RPMs.
This may or may not be ideal for you though- if you rock crawl with that, you might want a lower RPM clutch engagement, in which case, I can't help. XTM makes an adjustable slider clutch... You might want to look into that. If you want rocket ship takeoffs though, think about the Mugen setup. The aluminum will hold up great, it won't glaze and slip like composites, and it is still softer then the clutch bell, so it won't destroy your clutch bell.
Shoes-
http://www2.towerhobbies.com/cgi-bin...&I=LXJAP0&P=ML
Springs-
http://www2.towerhobbies.com/cgi-bin...?&I=LXNJ81&P=7
Shoes-
Springs-
Banned
My Feedback: (7)
TX
thanks man, i think ill go with the xtm for now and ill pick up the mugen setup just to try it out, thanks again josh
That's the one! I thought it was adjustable tho... Look at that surface area- I bet it would get good lower RPM grabs and not slip up high either.
