RC Monster Trucks Discuss rc monster trucks in this forum
MGT No breaks
Old 12-10-2005, 04:22 PM
ICrashThings
ICrashThings's Avatar
Default MGT No breaks
So yea, recently i noticed my MGT's brakes arent working so well. I keep playing with them but they have little effect. If i lift the truck up off the ground, give it gas and hit the brakes, the wheels stop, but if i try this on the ground it takes forever. Time for new brakes? or what? Im confused. []
Old 12-10-2005, 04:28 PM
PillowPants
PillowPants's Avatar
Default RE: MGT No breaks
Is your brake linkage tight enough? How about the brake pads, are they pretty worn?
Old 12-10-2005, 04:31 PM
ICrashThings
brake pads are ok, the linkage is tight, trust me, you slap on the brakes and try to move the tires they dont budge. I might just get a whole new brake set up soon. :\
Old 12-10-2005, 10:24 PM
sledmanass
sledmanass's Avatar
maybe your servo is getting weak, and not pulling the brakes hard enough.
Old 12-11-2005, 03:10 PM
think20
think20's Avatar
I had the same exact problem and I decided to go to my LHS and they put in a hi torque servo...this made a huge difference.
Old 12-12-2005, 09:42 AM
Greaper
You have to remove the spring and replace it with a piece of fuel line the exact same length. The factory spring is weak. Once I put the tubing in, it stops on a dime and no new servo needed.
G
Old 12-12-2005, 03:20 PM
ICrashThings
I did the fuel tube thing, I do that with all my nitros, im not a newb. :x
I went and put my old high torque servo on it. Works fine now, thanks.
Old 12-13-2005, 03:40 AM
beaglegod
Tubing had the breaks working perfectly for me too, wierd Ive read threads from others who didnt have success with this mod and some that did. I think when you replace the spring with tubing its a good idea to tighten the plastic nut so theres very little play, and of course remember to put the nut on backwards otherwise I doubt it will have a significant effect.
Old 04-20-2006, 11:20 PM
Rc EnthuSiasTs
Rc EnthuSiasTs's Avatar
Try the channel 4 mod.
Old 04-21-2006, 08:53 AM
badboy2
My Feedback: (13)
badboy2's Avatar
ORIGINAL: Rc EnthuSiasTs
thot this was for steering?
ill just get a nice servo and replace what u have ..
Old 04-21-2006, 11:29 AM
Rc EnthuSiasTs
Oh sorry, for a second i thought it helped out all the servo's. I shouldnt post late at night, little tired. Hope you fix your problem.
Old 04-21-2006, 11:49 AM
Wide Open
Wide Open's Avatar
ORIGINAL: badboy2
no, it goes to all the servos. if you have a 6 volt reciever pack and you do the channel 4 mod you will get 6 volts to all the servos. the battery slot in the reciever cuts the voltage down even if youre using a 6 volt reciever pack.
Old 04-21-2006, 01:47 PM
Rc EnthuSiasTs
Oh, that is what i first thought, thanks for the info wide open
Old 04-23-2006, 10:11 PM
badboy2
My Feedback: (13)
badboy2's Avatar
oh i always thot it only helps steering ..
Old 04-23-2006, 11:29 PM
Wide Open
Wide Open's Avatar
no, its supposed to route the full six volts to all the servos. also, i just did the fuel line brake mod today and its awesome. i hit the brakes from second gear and the thing nearly squatted to the ground. time to stiffen up the suspension!
