what kind of gas can be run in the warhead
WI
what kind of gas can be run in the warhead can u use top fuel case thats waht i run in my revo and was just woundering if u could or if u needed a diff kind fuel
RE: what kind of gas can be run in the warhead
you can if you want . traxxas says that top fuel is made especially for the trx engines but i'm pretty sure you can use it for your warhead. stick with 20-30% nitro. you can go with 15 if you want but 20-30 should be good
WA
It's not gas, it's r/c model fuel or nitro fuel, but if you really want to put gas in it......I would go with premium with techron, it's suppose to do wonders for your car's engine
one of my friends did that and it blew up nearly took his head off as the head of the engine went boom and missed him by inches
You can use any of the normal brands out. Traxxas, S&W, O'Donnell, Morgans, Blue Thunder will all work. I would run 20% to start and if you need more power then 30% but if you go to 30% don't forget to richen up the HSN and LSN so it don't run too hot.
AZ
ORIGINAL: camtheman000
so I take that as definitely NOT!!!!!
VA
If you put gasoline in a r/c motor, nothing will happen. It's flash point to high for it to burn, and while your spending hours trying to get it started the lack of lubrication in gasoline will wear out the internals of the motor. But hey, have fun.
LA
HAHAHAHAHAHAHAHAHAHA
ORIGINAL: bagged97
