steel spur..?
ON, CANADA
steel spur..?
I recently put a Mach .28 in my savage and its melting my spurs. I was looking into buying a steel spur gear and clutch bell, would that in the future eat my transmission? are they worth it? If that wouldnt help my melting spurs, should i try using aluminum clutch shoes...and if so what kind of shoes would be best? Are the HPI aluminum shoes good?
thnx
thnx
RE: steel spur..?
tron, if you are melting spurs it's probably due to clutch slippage, producing heat, melting your gears. I've had a few different engines in my truck, some pretty strong, and haven't had a problem with the plastic gears. I would definetely try the aluminum shoes before I invested the money in steel spurs. Many people, myself included, are leery of the steel gears because of what you mentioned, possibly hurting something further along the drivetrain. Hope this helps.
