MGT gearing
MGT gearing
For the mgt 4.60 SE, what is the best gearing for a faster top end speeds while losing as little bottom end as possible? How much MPH will this add?
OR
RE: MGT gearing
I run 16/48 ... It's got great top and bottom, it's noticeably faster and still pulls wheelies on command - I did put the FOC in it though. I think it's close to 40 but don't quote me on that, I haven't actually clocked it. The motor is the stocker but ported & polished too
FL
RE: MGT gearing
I run an 18 tooth clutch bell and 52 tooth spur most of the time with the stock 4.6. I don't run the stock tires much, usually savage tires or racing tires (bow-ties or crime fighters). It still has real good low end and the top speed is better than stock gearing. I've ran 18/46 before and it still had decent acceleration, but by no means was it doing wheelies with the stock engine. I also use the FOC.
Here is a little chart I put together based off a formula that was in one of last years RCCA magazines. I just picked 34,000 rpm as a base to go off, so the speed difference is the main thing to look at.
Rpm / final drive ratio X tire circumference / 1056 = mph
Tire diameter X 3.14 = tire circumference
Stock MGT tire is 6.75" diameter, so the circumference is 21.195" roughly
34000 rpm / 18.28 X 21.195 / 1056 = 37.33 mph
34000 rpm / 17.21 X 21.195 / 1056 = 39.65 mph
34000 rpm / 16.20 X 21.195 / 1056 = 42.12 mph
34000 rpm / 15.24 X 21.195 / 1056 = 44.78 mph
34000 rpm / 14.40 X 21.195 / 1056 = 47.29 mph
Gearing-----1st------2nd
16/52------26.43----18.28 - stock gearing
16/49------24.88----17.21
18/52------23.42----16.2
18/49------22.04----15.24
18/46------20.82----14.4
OR
RE: MGT gearing
nice chart Bria1, I'll have to copy and paste that[sm=thumbup.gif] .... that will also work with the LST1, the stock tires are the same height (I have both sets)
FL
RE: MGT gearing
I'm glad you like it. You could also play around with this gearing calculator from this MGT site
http://www.stc007rc.com/M****RUM/MGT_Gearing.htm
