axial .28 power
NY
axial .28 power
a few days a I bought an axial .28 for my savage ss
its better then the stock k4.6
the local rc expert said it the most power one for a savage. it fast but not what i expected
if money were no object whats the best engine engine all around (torque rpm ease to tune durability)
or is he right about the axial
IN
RE: axial .28 power
[link=http://www.nitrodynesystems.com/Engine%20Database.htm]Dyno results[/link]
Nitrodyne Systems database.
The Nova Rossi 528 took top honors.
Scott
Scott
IN
RE: axial .28 power
ORIGINAL: Josh222
yes but that engines over double the price of the axial. I have the axial and i can't keep the front wheels on the ground
He asked which engine to get if $$$ were no object.
Scott
LA
RE: axial .28 power
So how many gallons you guys get out of a axial .28? My sportwerks 26 is on it's way out and I was thinking of this engine.....Seems very powerful for the money. Longevity concerns have kept me from buying it......
AB, CANADA
RE: axial .28 power
If you want an engine better then the axial, easier to tune as there are only 2 needle settings, and has more power and good price, then get the LRP .28, I tried the axial, its nice, but LRP is better all around.
ON, CANADA
RE: axial .28 power
http://youtube.com/watch?v=UHbNdEaGZ4M on 15/49, trying 16-17/49 next[>:] are you sure yours is set up right?
RE: axial .28 power
I just put a Axial .28 1s in after my Top 528X Speed pull start broke and could not find a replacement pull start.
The Novarossi was sweet, lots of power and ran cool. The Axial is also a sweet motor, it's a little less powerful, but you hardly notice it bashing. If it was on the track, the Top would smoke it.
RE: axial .28 power
I bought an Axial after the stock .21 in my MGT died. I could do wheelies, but I had to have good traction. It didnt have very good top end, and not alot of torque, but the mid range is where it shined. Then I bought a Team Orion Wasp .28, and that thing is a freakin beast!!! It can flip itselft over with ease, and with a steady throttle finger, I can easily make it hold out a wheely. It has the most torque of just about any .28 I have seen, as well as a super top and mid range. Its a bit harder to tune because it has 3 needles to mess with, but it holds the tune well, so far I have had 5 gallons through it and it hasnt had a hic up and is still going as strong as when it was new, and it doesnt cost much. I would really reccomend it.
RE: axial .28 power
ORIGINAL: Josh222
RE: axial .28 power
hey guys, have any of you had problems with the carb o rings failing?, I have had my axial .28 for about 3 months and i have already gone through the high speed needle o rings, and now the mid range o rings are shot, anyone else have this problem?
FL
RE: axial .28 power
Hey guys, I want to replace the stock engine on my Warhead, i just upgraded the complete truck to aluminium parts.. no plastic at all. What engine should i get? The best options... according to my knowledge are:
1. Axil .28RR (new version of the .28)
2. Axil .32
3. LRP Z.28R (truggy version with no pull start)
I will highly appreciate any help.
2. Axil .32
