4.4cc=.what
RE: 4.4cc=.what
*raises hand*
Multiply cubic centimeters by 0.061023744 to convert it to cubic inches.
4.4cc * 0.061023744 = 0.2685044736ci = 0.27
To convert ci to cc, divide by 0.061023744.
OR
RE: 4.4cc=.what
I'd go with the .28, it's got higher RPM's and only just slightly under the torque of the .32..
Here's a link to the NitroDyne database.. [link]http://www.nitrodynesystems.com/Engine%20Database.htm[/link].. you can see how close they are there.
OR
RE: 4.4cc=.what
It tops out at 35K (the .28).. looks like it's about 1000 RPM's (or so) better, but I'm not sure on actual RPM's for the .32, that's just what I can see by the chart at NitroDyne..
Here's another link to check out.. [link=http://www.xtremerc.com/forum/showthread.php?t=2202]more #'s[/link] ..they don't have the .32 results there though, just the .28.
RE: 4.4cc=.what
or you can use googles calculator feature, jsut type in the search bar- 4.4 cubic centimeters in cubic inches and it will give you the answer
or any other calculation it will give the answer straight up,
4.4 cubic centimeters in cubic inches = 0.268 CI
