RC Monster Trucks Discuss rc monster trucks in this forum
re: receiver battery?
Old 02-24-2003, 11:00 PM
kevin1467
Default re: receiver battery?
I would like some input on what receiver battery (6 volt) that you think is the best? putting it in a t max. thanks
Old 02-25-2003, 09:53 AM
XR2PROBE
WELL IF YOU ARE LOOKING FOR A NEW SET UP YOU CAN MAKE ROOM FOR A BIGGER RX PACK BY SIMPLY MOVING YOUR GAS TANK TO THE FRONT OF THE CHASSIS WHERE THE RECEIVER IS LOCATED AND PUT THE RECEIVER WHERE THE GAS TANK IS...........THERE ARE 2 REASONS HAT I FOUND FOR DOING THIS
1 YOU WIND UP WITH MORE ROOM FOR A LARGER BATTERY FOR YOU RECEIVER AND SERVOS................
AND 2 IT PUTS ALL THE SLOP ON ONE SIDE OF THE CHASSIS WHILE MAKING ROUTING OF THE SERVO WIRES AND CONNECTIONS EASIER TO DEAL WITH ..........AND ALL YOU HAVE TO DO IS DRILL 5 NEW HOLES FOR MOUNTING OF BOTH...........
O YAH THERE IS ANOTHER REASON FOR DOING THIS ............IT WILL SAVE YOU THE HASSLE OFTRYING TO REPLACE THE SPUR GEAR IF YOU SHOULD HAPPEN TO STRIPP IT..........AND IT MOVES THE WEIGHT OF THE FUEL ONTO THE MOST IMPORTANT PART OF THE TRUCK................. THE FRONT WHEELS
I KNOW THIS IS A FAR CRY FROM YOUR QUESTION BUT TO GET BACK TO THAT............
I WOULD PICK UP A SET OF ORION 2700 MAH AND ASSEMBLE A 4 CELL RECEIVER PACKWITH DEANS CONNECTORS TO SUPPLY YOUR RECEIVER WITH POWER AND WITH THIS SET UP IT WORKS KILLER
Old 02-26-2003, 01:10 AM
Krusty
XR2PROBE,
Is your "cap lock" stuck, or do you like SHOUTING at everyone?
Old 02-26-2003, 03:17 AM
XR2PROBE
HEY ALL IF YOUR GONNA GRIPE AT ME FOR CAPS LOCK BEING ON........JUST REMEMBER ALL EYES ARE NOT CREATED EQUAL I AM LEGALLY BLIND AND I AM WORKING WITH A 13 INCH MONITOR SO FOR RIGHT NOW UNTIL I CAN AFFORD A NEW MONITOR YOUR STUCK WITH THE CAPS FOR AWHILE
Old 02-26-2003, 03:38 AM
Krusty
Originally posted by XR2PROBE
I AM LEGALLY BLIND
How are you able to fly airplanes and run all those cars? I'm not "legally blind" and I have a difficult time seeing when I fly. Do you have any "tips" for me?
Old 02-16-2004, 10:53 AM
Schmernst
Default RE: re: receiver battery?
Does the orion setup last long? I just put a venom 1100 mah 6 volt in my t-maxx..... great response but the juice ran out way too quick. two of them ran out in only 1 1/2 tanks.
Old 02-16-2004, 01:44 PM
RaZ_Tx
RaZ_Tx's Avatar
you want a 6v(5 cell) rx pack not a 4.8v(4 cell) the servos will be severely under powered and the 2700 mah cells he was talking about are the sub C size
