Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks
Reload this Page >
serious problem on my terra crusher
RC Monster Trucks Discuss rc monster trucks in this forum
Old 03-09-2003, 05:04 AM
badboy2
My Feedback: (13)
badboy2's Avatar
Default serious problem on my terra crusher
today we were havin fun runnning on an asphalt road and my brother decided to run my tc on snow so everything is doing well climbing little jumps from the snow ..until i hit a paved snow and so i tried to reverse and it wont go so my bro picked it up and faced it toward me so from there 20ft. run it towards me came this unusual sound and then as soon as i stopped it to checked what was wrong i here this sound something like a fan rotating and hitting something like a leaf..then i tried to run it again..it wont go either reverse or forward..t just kept on revvin i lift it up to see if the tires are turning and they are not.what do u think i broke..is it the transmission?man what a day..and yes i was CRUSHED! aaarrrgghhhh!
Old 03-09-2003, 05:09 AM
LandShark
double posting?
check front and rear drive shaft. if they are ok, turn the spu gear
with you hand and see if the shafts are turning.
if the shfts are not turning, may the tranny has some problem
Old 03-09-2003, 05:21 AM
badboy2
My Feedback: (13)
badboy2's Avatar
sorry about that double posting..thanks
Old 03-09-2003, 05:49 AM
BUGGIES_R_US
BUGGIES_R_US's Avatar
TIP:
Any time you hear ANYTHING wierd, STOP.. do not drive it towards you !
I have learnt this the hard way. This way you will minimize the damage and you will have a smaller area to search for parts! lol
I cant help you directly but I think what you might wanna do is think about the physics if what you did leading up the the failure.. landed too hard? Hit something causing a high-G shock?
-ram
Old 03-09-2003, 09:51 PM
shahar
your problem is most likely a spur gear worn.It is the plastic gear between the engine and the frat,and my guess is the snow ride was over loading the tooth till they worn out. u can view the spur by removing its cover held by 1 clip.If u notice a white dirt inside its sure. if u didnt re-tighten the engine mount screws it will loose and the spur gear will not survive.
Old 03-11-2003, 12:06 AM
psycooclimber
If the cluch is spinning it is probibly in the tranny.
if the cluch is not spinning it is probibly because it has a broaken piston arm or crank shaft.
Old 03-11-2003, 01:57 AM
cummins driver
My Feedback: (31)
cummins driver's Avatar
If all the driveshafts are in place, then sheck your spur gear,and if it is good,then your transmission is either not going in gear,or you have broke a gear,or the shifting mechanisim inside the gearbox probably.
Old 03-11-2003, 05:27 AM
badboy2
My Feedback: (13)
badboy2's Avatar
thanks for all your help .. i think it was the tranny
Old 03-19-2003, 12:56 AM
flyinglow
My Terra locked up in forward. Took the tranny out and opened it up where I found an extra bearing in the bottom of case jamming the gears. Only had it for a couple of days so will take it back to dealer and test out warranty. Guess it got dropped in there and left at the factory.
Old 03-19-2003, 11:35 PM
cummins driver
My Feedback: (31)
Sorry to hear about the bad luck.I bought a tower nitro st-15 brand new,and it wouldnt even run when i took it out of the box.Got that fixed,but now it doesent run at all,and i wish i had spent a little extra and got something better like a rc10gt,or a nitro rustler,or a duratrax maximum mt.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
