View Poll Results: A poll
Voters: 41. You may not vote on this poll
CEN or HPI or Traxxas
RE: CEN or HPI or Traxxas
ORIGINAL: JATO11
Is lst 2 and mgt by losi
ORIGINAL: JATO11
I dont know what is better the CEN GST 7.7 or the HPI SavageX 4.6 i want one that wheelies good fast speeds and good handling
I would totally scratch off T-Maxx from your list. If you want Traxxas, get the Revo. The Revo is a way better truck, and in many respects with little mods, even tougher than the T-Maxx!
The Revo is the best handler out of the pack, has excellent speed, acellereation and top speed wise. Though all these trucks have similar top speeds, the Revo will get there much more quickly.
the revo is the best if you are looking for a track weapon, and with a few mods can take a lot of abuse (although i am a fairly heavy basher and i am yet to make these "must have" basher mods because i am yet to break the stock parts) but it will not easily wheelie without a very well tuned engine and the suspension right.
CA
I have a Genesis same as the GST except for 3-4 mods. you can make these handle very good with the right shock set up. Mine will wheelie no problem and still give my friends LST w/pico a run for his money. If you want to save some serious money pick up a used Genesis LIMITED the difference between the limited and the GST are:
This is from CEN
The main difference is the brake syste,m (GST uses the nemesis set-up) and the servos and radio are slightly different. Also the motor has been improved with slight porting and timing differences.
Thanks for the great questions,
Customer Service
I picked up a Limited for $220 RTR
This is from CEN
Customer Service
Out of the three CEN MTs, does all three (Nemesis, Genesis, & GST) come with the center diff and front/rear MTM brakes? These alove are innovative and what catches my eye when looking at monster trucks.
OR
I'm pretty sure that the Nemesis was the 1st to come with the center diff, that being why there's a need for the rear brake.. I don't think the Gen LE has the center diff.
CA
the Genesis, Gen LE and GST all have a 3 speed tranny w/reverse, the Nemesis has a 2 speed no reverse. They didnt put a 3 speed in the Nemesis because it is geared more for track use. They also didnt add the upper horizontal shock and a few other things to save weight.
The Nemesis and GST both use MTM brake system. The Genesis and Gen LE do not.
People talk about part being hard to get but if you go on ebay you can usually get replacement parts and the upgraded GST parts pretty quick and cheap!
You can go to the site below to check out the three CEN trucks we are talking about too
http://www.cenracing.com/rckits.html
GST rules... its a very impressive basher. I raced mine sometimes. Its not as quick as the revo but it is as competitive as the LST with some simple mods.
all GST has center diff and MTM brakes
As for getting CEN parts, I am trying to build GST/Genesis/Nemesis diffs to put into my Savage ue to their reknown durability. I am having probs finding on e-bay or anywhere elses where someone has a GS002 (I need another 4bevel spder gear set) and the outer bevel gears.
RI
ORIGINAL: SAVAGEJIM
