TNX hop-ups for racing?
FL
RE: TNX hop-ups for racing?
I don't have the 5.2, but I have the 3.0. Start with better tires for the track, a stronger steering servo, a stronger servo saver, and better rod ends for the toe links for now. My 3.0 really didn't need much. I added a wing to rear also. I'm not sure on any shock set up, I hear the stock shocks work ok.
ON, CANADA
No. It kinda prevents damage to the steering servo when the front wheels hit bumps.
The 5.2R comes pretty well equiped stock. You might want to protect the engine head better and play with suspension settings(stiffer springs or damping silicone oil change)to suit your driving preferences.
Also a different tire choice should improve things alot.
The .32 engine is legal for your racing?
FL
ORIGINAL: Trend
what does the servo saver do? does it strenghten the servo on turns?
