IS THERE ANY DIFFERENCE BETWEEN 17MM & 23MM HEX ADAPTERS???
Hi guys!!! I just need to know what is the difference between 23mm hex adapters and 17mm hex adapters.. I am building a race Revo with a O.S. .21 V-Spec Engine and I need to know if there is any advantage of one over the other for racing purposes.. Thanks
My Feedback: (35)
RE: IS THERE ANY DIFFERENCE BETWEEN 17MM & 23MM HEX ADAPTERS???
ORIGINAL: xtreme_ntc3
17mm is a tad smaller than 23mm anyway the last race revo I built I used an O.S 18, Bowtie's on dish rims, and Ofna 17mm adaptors. IMO all you need are 17mm no need for 23's plus you have way more rim choice's with 17mm
Thanks for the reply, but I am more interested about the possibility of any advantage in performance (if any).. Thanks anyways!!!!
OR
The 17mm are probably going to be better. Less rotating mass, less strain on your axle stubs... and should still be larger enough so they won't strip. I'll be switching from 23 to 17 soon..
ORIGINAL: duckedup
Of course, such racing situations are very very rare at the local track since driving skills vary to a very large degree. Now at a nathional champion ship where all the noobs and novices are weeded out...the drivers will all be culled to the best of the best where all are nearly equal in the best skills possible.
Back to the 23vs17mm hexes: 23mm also has the advantage of excerting more torque on the inner hex of the rim. Additionally, 23mm has the advantage of more surface area on the hex sides. The increase hex side area is the one factor that prevents rim hex stripping. It can take a considerable amount of torque before the rim hexes strip and the adapter hex turns in it.
what ever you do dont buy maximizer B locks you will snap the rings soooooo easly
OH
a track in CA at a proline maxx challenge landed on right rear tire and i hit the straight and my tire started to wobble off i snapped the right rear inner ring and cracked 3 spokes and a week later with a new set i broke the hex off the spokes at another race.
