radio problems
Banned
radio problems
Hmm , my transmitter is going bonkers, when I throttle it , it thottles on the braking , and the braking is the throttle lol. How can I reverse this?
GA
RE: radio problems
Which radio?
For most of the less expensive ones there's a servo reversing switch somewhere n the unit. The electronic radios usually have a setting in the menue.
RE: radio problems
Use the "SEL" button to scroll through the menu 'till you find "REV-ST". (14 clicks on mine...)
Then use the "CH" button to select "REV-TH". It will say either on or off.
Then the "+" button to change it. (if it's on you want off, and vise versa)
Be sure to re-check your EPA's....
RE: radio problems
Hmmmmmm...now I'm stumped.
Maybe someone else will chime in....
You have lightening strike or something? Why did both your radios act up???
