my rear diff is ticking
hello,
i have MGT 0.21 with MACH 427,
now i hear my rear dif is ticking!
i opend the ditt box and all look OK.
when i stop the front wheels and spin the rear the diff is tickin!
the pinion and all looks good
what the problam?
thank you for help.
matan.
this is pic of the pinion
http://img229.imageshack.us/img229/5327/pict0082xp6.jpg
what the problam?
thank you for help.
matan.
1 Post
RE: my rear diff is ticking
The pinion gear is skipping over the ring gear. [link=http://www.monstergt.com/articles/transmission_diff_shim.php]This[/link] is the fix
I've had the problem in the past and pictured below is what happens if it goes unchecked. Since shimming i've had no problems whatsoever.
so i can to buy new pinion or to do this Process?
or if ill buy new pinion it is not good and i need only to do this Process?
i ask it because i dont have how to short the cap...
thank you.
thank you.
1 Post
From the look of the pinion you can do this process without buying a new ring & pinion set. It is however recommended for ALL diffs, whether they are new or not (they are not shimmed properly from the factory, it's not something that develops over time).
To shorten the cup you don't even need digital calipers, just file away until it fits
i think the same thing has happened to my t-maxx, front diff,,, i use i high torque servo for my brakes,, and everytime i hit the brakes i get this loud crakling noise from the front diff,,,, will shimming it solve my problem!! thanks,
i also checked if my diffs were worn out just by holding the rear wheels tight and turning both fron wheels,, after a certain amount of force was applied the diff started to skipp!!
what should i do??
what should i do??
Hi all!
I buy diff case and shime.
i change the case and put 8X10X0.3 shime
i spread grease and assembled all.
i go to run it, and agian! it ticking!!!!
now i put more grease and one more shime 8X10X0.2
and its ticking
what to do now????[:@][:@][:@][:@]
thanks all!
and its ticking
thanks all!
1 Post
If you've shimmed it properly and it's still clicking it's probably be too worn and needs replacing.
You have checked it's not the other diff that's now clicking haven't you?
no, its not the front is ticking..
when i push the rear wheels and stop the front its ticking(the rear)
when i push the front and stop the rear all good.
the problam that i cant buy new diff, in my country they dont sell parts for MGT..
