titans 550 vs 600s ?
Curantly I have an emaxx with 2-7cell 4200 packs and its fun to break wheelies with it. I recently purchased 2 600 motors online and tried them out with the same set up and they wont wheelie and my run time seemed shorter. I aslo expected more speed. Does that sound right? Should I have changed the gearing or added more cells? Feel free to set me straight. Seems like the titans perform better with the same voltage.
MI
RE: titans 550 vs 600s ?
Bigger motors need more voltage...they should provide more torque so in gearing you should be going up in pinions or down in spur size.
Also don't forget those 600's weigh a good deal more...
hmmm...I guess that gives me something to play with. Ill try deffernt gearing and see what turns up. Think its safe to run two 9 cell packs?
NV
If you are running your stock evx controller then I think 6 cells would have been the max with 600 motors if they are the s-600 everyone generally gets. Generally bigger motors do need more voltage, but if you bought lower turn motors than the stock 550 then they would spin faster. I would not have tried with 14 cells and I would not try with more unless you check temps on your speed controller to make sure you dont burn it out. Maybe play with the gearing a little and see what happens. Post which motors you bought so we can give you better advice.
The motors I bought were Dual 600 size motor power pack for E-Maxx 12V - 24V on ebay for 11.99 plus shipping by maddmaxx motors. They didnt generate alot of heat but I did notice they were rated at 18,800 rpms which is about 1000 less to the titans so I think your right about the pinion.I do appriciate your input. So to add more cells for these size motor, would I need to upgrade my esc to a novak supper duty? I guess we are all just trying to find the best bang for our buck. How do you feel about the Kershaw brushless system?
