Is MIP's clutch kit for the T-Maxx any good?
I installed one in my RC 10GT and it was a night and day difference between it and the factory clutch setup. I'm just wondering if it's that much better for the T-Maxx.
Grampi, I would have to guess that anything MIP puts out, it's going to be a good product. As far as better than the stock T Maxx clutch, I would think that anything better than stock is going to be just that.... better. I don't like the herky jerky action of the stock clutch and will probably be looking for an upgrade soon....
IL
the jerky action of a stock t-maxx is not from the clutch on the engine. its from the internal finger type clutches that operate the forward and reverse selection. the only way to stop the jerky start is to do a forward only conversion. as far as clutches.. in the past I found that the MIP clutch is no better than the stock maxx clutch.
My Feedback: (13)
IN
Yah isn't it kinda stupid that the Tmaxx Sport or whatever GRAMPI!! SPORTMAXX comes with a single speed transmission... and for 325$ it should have 2 speed! THEN the Tmaxx, which most ppl rather have forward only, comes with that annoying reverse so you have to buy something totally different to get that.. for 400$ give or take, id much rather it be an option like the Savage.
My Feedback: (13)
IN
Originally posted by grampi
I'm thinking the Sportmaxx with the 2 speed and 4WD modules would be the way to go.
WA
Originally posted by CaseyDDR
why would u want 4wd if your buying a sport maxx? im confused... I personally dont like 4wd, slows down the vehicle.
My Feedback: (13)
IN
Originally posted by jeeptuff
That is a little thing called preferance, Grampi has a screaming GT, I think he knows what he is doing.
The sportmaxx is intended to be a racer. It out accelerates the T Maxx. I think the only way the T Maxx would stick with the Sportmaxx on a track, is if it's a big track with long straits where the T can kick into second gear and get some speed up.
I did some looking up on www.buytraxxas.com and if you start with a Sportmaxx $325 add a 4WD conversion $50 and then add the two speed tranny $35, you get a grand total of $410. Which is more than what you can find a T Maxx for and take out the Reverse. Now I know prices will vary, just wanted to give you something to thing about.
I have been very tempted as of late to buy a Sportmaxx and just see how much better, if any, it is than my T Maxx. I would like to see just how much the 4WD helps out, or if it's really all that necisarry. Granted it will help out a lot with crawling at slow speeds, but I don't find myself going that slow very often. Just a couple of thought I have had. Good Luck Grampi on getting the one you want. Either way they are a ton of fun....
OR
Just out of curiosity, why would you not want 4wd on an MT?
The idea of an MT is to go over as many obstacles, drive in terrain where normal ST's/buggies can't go and jump higher/farther. This seems to be suited perfectly for 4wd.
MT's are not built for speed, though some can go quite fast. For my self It makes no real sense to have a 2wd MT.
The SportMaxx was designed to allow people to get into a MT cheaper and add the 4wd, 2 speed and reverse at a later date when the owner has a little more money. Just because it doesn't come with it doesn't mean it shouldn't have it.
One other question for you knowing you own an E-Maxx. If you like 2wd so much have you converted your E-Maxx to 2wd? If not why?
The reason I mentioned the Sportmaxx and suggested adding the 4WD and 2 speed modules is because then you could have a T-Maxx wihtout reverse. I wouldn't say MT's weren't meant to be fast. There are several that will exceed 40. That's pretty darn fast in my book. There could be an argument for or against 2WD MT's. You're still getting the ground clearance with either, and like was mentioned, there's usually less driveline drag on a 2WD so in theory they should be faster. I went the T-Maxx because I wanted 4WD AND speed along with the ground clearance.
My Feedback: (13)
IN
T Maxxes have been so popular, they have really developed their own racing class. I know that most racing MT's fit into the hybrid catagory, which seems to me to be a big version of a buggy. I asked once what a hybrid was, and one answer I got was MT crossed with a buggy.
As it has been stated a few times in this thread the Sportmaxx is really for those guys who want to race. I am a basher, and I want 4wd. I like the speed, handling, and toughness of the T Maxx and am having a blast with it.
Grampi, I got your point on the Sportmaxx and adding the mods to it. I was just saying it would probably be cheaper to get the T Maxx and take the reverse out. Plus in true form of the RTR it's ready to go, how you want it, out of the box. Well I guess you would have to buy to FoC if you wanted to take reverse out....
My Feedback: (13)
IN
yah with what they do to the MT's to get them 'race ready' does kinda take the MT outta it.. Like on my emaxx for MT class I'm probably going to use 4 1/8 buggy shocks, the center of gravity will be much lower with new chassis, and it will be longer.. simple conversions totally change the size of a maxx.
My Feedback: (13)
IN
Alot easier to get the truck to idle and not stall. With reverse the tmaxx is jerky. It will run alot smoother with out it.
From what I hear it smooths out the T's acceleration. At very slow speeds it tends to jerk forward, but once it gets up to a certain rpm's it's fine. This only occurs from a dead stop.
I could see how this would be a problem for racing, but as a basher I find there are times when I need reverse to get out of a situation where I am too lazy to go pick up my truck. I really don't think I will ever take revers out of my truck.
If you want to see some racing MT's and Maxxes, go to this website. http://www.johnnycoolguy.com/JCGR/ph.../dan/index.htm
My Feedback: (13)
IN
Originally posted by Dlock
I have not really had any problems getting my Max to idle, and I have the reverse in.....
I know id' have this problem personally if i decided to go to the evil side.
What has CMO been up to lately? He used to be a regular in this forum, but lately he's been pretty scarce. He's missed.
My Feedback: (13)
IN
wonder if i'd be missed if i was gone :*( oh well :sigh: lol anyways yah thats not fair, i will wnat help if i decide to go nitro but nobody around me has anything.. all the RC'ers in indy are on the east side, and i live less than 1 mile from the county line on the west side.... lol its at least a 30 minute drive to our local track
