savage brake/throttle setup
Hi there,
I cant seem to get my brake and throttle working correctly when i apply the brakes and let go of the throttle... ..i get to 1/4 -1/2 throttle... i have tried adjusting it but i cant get rid of this throttle comming on after applying the brake if i adjust the dam thing my throttle arm just slips any tips?
put a little bit of grease on the screw that holds the L shaped servo arm in place mine was binding and it fixed the problem also make sure you put a couple of dops of after run oil in the carb when your not running the truck so it doesn't stick
