Race Setup for T maxx........
I was thinking of going wsoem type of JT Race Chassis w/ either the SM EXT or Race Suspension. Also can you tell me what some of you guys are runnin and how the setup works for you? thanks Alec
WY
Depends, are you running a small block(.12-.18) or a big block(.21-.26)?
Either way light products=better performance. But stronger products=longer life and reliability.
But for a basic run down on a small block truck Id start with these.
A strong chassis/chassis braces
Stock arms w/cvds or Proline suspention w/cvds(keep the bulks plastic)
4 1/8 shocks (ofna, kyosho............)
FOC(forward only conversion) for the tranny UE 8mm or 10mm is the best.
Spooled rear diff
cut down body posts
Good high speed/high torque steering servo
Good high speed throttle servo
Ue servo saver, or proline servo saver
some lightweight rims(RPM CLAWS are the lightest)
some good racing tires(bowties, pacmans, or micros)
Titanium hinge pins/and tunbuckles
RRP dual disc slipper
Dual brake disc mod
aluminum pillow balls
theres alot more that Im not thinking of right now!!
It all depends on your application and track rules. Give me some more info on what you want to build and I can give you some idea's.
BTW I run a snorty .247 maxx
Spooled rear diff
cut down body posts
Dual brake disc mod
WY
Good race proven small blocks not in order
-Picco .15 awsome have ran about 5
-Os cv-rx .15 tons of torque
-Rb C12 .12 best .12 for that application
-TRX .15 race engine with rear exhuast and slide carb(2.5)
