engine question
engine question
when i start it i have to lean it out then once its runnin i richen it a quarter of a turn to run at 255
if i leave it itll stall at high speed and run at 295
but when i run at 255 when i let off it goes to a low idle and boggs a little when i accelerate is it my low speed needle?
or somethin else
its a mmgt by the way
im using a cold plug
or somethin else
TN
RE: engine question
keep hsn where itll run at 255 and slowly lean the lsn if that doesnt work then start back at factory settings then c what u need from there always make sure there is a good smoke trail when accelerating also there is a pinch test to see if lsn is set correctily search the forum or search nitro pinch test with Google
RE: engine question
yes there is a good smoke trail.
when i test the temp i put my duratrax temp gauge touching the zipties on the cylinder head pointin towad the glow plug and it reads say 255
if i put it pointin at the glow plug outside the cylinnder head about level with the carb it will read about 25 degrees cooler. which place is correct?
TN
RE: engine question
pointing down the cooling head touching the zipties toward the glow plug. here is a link to tuning and the pinch test http://monster.traxxas.com/showthread.php?p=2451270
and here is a very good video that will help http://www.youtube.com/watch?v=oSmMzpZM_As and the second one http://www.youtube.com/watch?v=BJFsJ...eature=related
also let me know if u get it going good
RE: engine question
well thanks for the videos, i got it goin really good now i could still lean it out a lil but ill wait till i get to the track.
