1 way bearing
PA
1 way bearing
hey knoxville here does anybody know if the 1 way bearing is supposed to be greased or not because mine slips pretty bad! or does anybody know what the problem could be?? Also does anybody know the air-fuel mixture for nitro thanks in advance
1 way bearing
It's not supposed to be greased. That's why it slips. I heard that if you spray some nitro cleaner in the trans hole, then let it drip out, you can clean the grease off and it should be fixed.
1 way bearing
One way bearings slip because they get dirty. Just clean them with nitro cleaner and lightly oil them. This is for both, the one in the transmission and the one if you have a pullstarter.
