Best steering servo for Savage?
I broke mine during break in.
I purchased a hitech 945MG high torque servo, which turn s the wheels while the truck sits still. Then i went to my LHS and bought replacement gears for my steering servo , repaired it and am now running it as my throttle/brake servo.
Also there are alot of other threads out there regarding this problem. Its a major weekness in the savage. But one that can be repaired for a $50.00
i stripped mine out within2 days...bought hitech 645....wasn't impressed...has metal gears but not very strong for a supposed 133 oz @ 6 volts. They tired to sell me a $137 servo but i went with the hi tech because metal gears and had good specs. Iwas orig gonna get the hi-tec 625 has better spec but tried to save $20. Like to hear anyones thoughts on the 625 if they have experience with it.
i realized after i put it in i had it backwards...all i did was put the control in reverse mode. Will it creat more torque if i pull it out anf turn it around? The wheels fade bad at high speed.
Actually now that i think about it... i didnt put it in backwards (cant do that cause arm wouldnt reach) So why do the stock savage servo come set the other way and in reverse setting? Im a little boggled..or doesnt it matter which way the servo turns naturally?
I run an Airtronics 94358Z and haven't had any issues with it...especially after I replaced the servo saver with something stronger.
I've run probably 2 gallons worth of bashing with this servo installed.
i got the digital version of the 645. for $50 it was a great buy. it has something like 168oz at 6v. it turns the wheels while on the ground..even on carpet. check it out at servocity.com free shipping in the US too.
Hey Gopher,
Are you running the stock tires?
Thanks for the info on the servo. I have been leaning towards the digital instead of the 945.
Thanks Shark,
I see what you mean. I would have thought the digitals would have been faster (5645). This one looks cool though http://www.servocity.com/ServoCity/P...coreless.html. Almost the same speed as the 945 your using. What did you use for the throttle?
