tranny problems (i think??)
hey guys, i was driving my stampede vxl yesterday when all of a sudden it stopped moving. I went inside and took it apart to find that the spur and pinon gears were both moving when i used the throttle. I then took apart the transmission for the first time and I think i found the problem. One of the gears was missing the peice to prevent it from sliding on the shaft. So i have two questions 1. what is the peice called and can i get it at a hardware store and 2. do you guys think that my theory is right or could it be something else, like i said its my first time opening the tranny and im hoping its one of the last because it makes me nervous and stressed out. thanks for the help this site is very helpful and ive been learning a lot.
My Feedback: (33)
RE: tranny problems (i think??)
ORIGINAL: paythemanning
alright thanks... anyone else. i would hate to buy a brand new tranny cause i cant find a piece to fit.
I just checked the manual for my nephews Stampede and the part number is 3793 which is the shaft and pin .
http://www.horizonhobby.com/Products...ProdID=TRA3793
are you sure thats the part because i see threads on it..what would it screw into. the part i am missing can be seen on the pics and it doesnt look like it would work, but you may be right idk thanks a lot for the help though
My Feedback: (33)
Well from the pic it looks like you are missing the pin that holds the metal gear in place on the top shaft . That is the only gear that needs something to stay in place .
ok...i called traxxas and they said that the part number is 3793 which is the one suggested ..thanks a lot for the help and ill order the part right now.. thanks again
