Need Help w/ Savage Order
So far This is what I have
1 Savage $380
1 El Camino Savage body
Savage Dog Bones (Chrome Heavy Duty)
1 Savage Hi Pro Air Filter w/ extra foam
Is the Air filter I listed any good?
Wbat is the best filter?
Is there anything else I should order?
Should I get the 11 fin aluminum Head for $30?
I can do some upgrades later but im wondering if this is all I need to have a good running savage?
Reverse modual?
Aluminum head?
Stronger Servo?
Also, What else will I need with this kit to get going?
What kind of gas?
Glow Plug?
Glow Plug ignitor?
gas bottle?
Please let me know as I am new to nitro.
What should I locktight?
1 Savage $380
Reverse modual?
Aluminum head?
Stronger Servo?
What kind of gas?
Glow Plug?
Glow Plug ignitor?
gas bottle?
i would get a stronger steering servo like a hitech645mt or comparable..
20%Nitro
You need glow plugs i run A5, a glow plug charger, fuel bottle
Then go out have fun and when something breaks then worry about upgrading, because things will break.
20%Nitro
how bad is the stock servo? Do I need a special battery pack?
So with these couple things I'm getting I should be all set?
TX
You won't need a "special battery pack" to run the truck, but either get some rechargable batts or a hump pack for it or you will have to spend a mint on AA's!!!
MI
Batteries
Oh yes the battery thing. The 5 cell hump back is the way to go. You will need a "special" charger for it if you get the NIMH but its worth it. The AA rechagrable are NOT good because they only put out 1.2 volts, you can only install 4 cells. AA alkaline are 1.5v, you need the power (volts) for the truck. You will come out ahead in the long run with the 5 cell. Dave
WV
Dogbones
Maybe I overlooked them but I've been wondering... Where are these freebie dogbones? I found an extra filter, some body pins, & some little stuff but no dog bones.
MI
The lastest Savage 21's have them in the box. I bought mine 3 weeks ago and they were there. The kit was right from the distribitor to LHS. Maybe they ran out of extras? Dave
i think im going to order from savage central instead to avoid tax.
they only carry titanium dogbons for $28 and from the sound of it i can wait for the dogbones.
is the stock filter good enough? im going to be running the truck in sand.
what else should i get for the truck? Ca I use a regular 6 cell battery pack like i use in my electric cars? id rather use disposable batteries since i will be camping
im going to buy the el camino body too.
besides the body and a fuel filter what should i get? should i stick to purple?
TX
Forget the body for now and buy the motorsaver air filter. You will need it in the sand as the stock one will clog up easily. Also a 6 cell flat pack will not work in the savage as there isn't enough room. Check the store at savage central, O has a couple of 5 cell hump packs that work great. Remember to get a charger for the battery pack as well.
as far as the 5 cell pack how can I charge it when I have no plugs? how long will it last?
So all the Savage need is ome locktight? (Where) and an air filter?
Should I get a stronger servo?
is this the motosaver? http://store.savage-central.com/prod...products_id=60
TX
Buy the 5 cell hump pack and charger from savage central and you are all set. As far as locktite goes, you should lock down any screws that go into metal threads. No need for a stronger servo for now, I have had no trouble with my 2 savages.
how can i charge the 5 cell without a power outlet?
can i buy this later or is it necessary becase $50 is alot more money (battery & charger)
also, is the air filter in the post above the god one? (motorsaver?)
should i stick with purple?
thanks,
JI
thanks,
JI
TX
You will have to have some way of charging the batteries unless you want to go with disposables. The motorsaver filter is one of the best if not the best and color choice is a personal preference so you can make it unique to you.
TX
I went to your link at savage-central and that is not the motorsaver filter. I did check at extremercmotosports and they have them. Here is the link http://www.extremercmotorsports.com/...=HOME:SAVAGEUP
http://store.savage-central.com/prod...products_id=40
is this it? it is cheaper than the one i linked to above
i like blue more than purple, but many parts seem to come in purple only
http://store.savage-central.com/prod...products_id=62
this one?
this one
ot this one?
which one is the best?
this one?
this one
ot this one?
which one of those three is the best? air filter being extra important for the sand
also can i quickcharge the humppack wirh an old battery charger i have for my electric cars?
im ready to order after someone answers these questions, the other place you mentioned is cheaper but they don't have as many parts.
Originally posted by fourwheeler
Buy the HPI motorsaver air filter. I don't know about the charger so I can't answer that.
do i really need the humppack? cause it looks like its 50+ for the humpack with a charger and for only 1.2V more?! im trying to spend under $460 on this whole savage thing.
