duratrax MAXIMUM ST
VA
duratrax MAXIMUM ST
i got a deal of this truck (duratrax MAXIMUM ST) plus 6 pairs of new tires just for $50. well the truck after all runs but after plus or minus 30 minutes of run time the clutch melted. (not the clutch on the engine) i took out the tranmition to take out the clutch but can't find a way to take it out. any suggestions?
RE: duratrax MAXIMUM ST
not real sure on what you have to do, but these might help you.
http://rcdocuments.com/Duratrax_Maximum%20MT_Manual.pdf
not a 100% on what the diff is in the pro i think its only a few small things but there more or less the same
http://rcdocuments.com/Duratrax_Maxi...arts-Views.pdf
http://rcdocuments.com/Duratrax_Maxi...Pro_Manual.pdf
hope that helps
hope that helps
