Just bought a T maxx It has associated shocks and ...
What kind of springs and oil should I use I think it is bottoming out to easy ... Any other suggestions i will listen Thanx
Those shocks,
Are a smaller in diameter then most others out there! I have a set and springs from other shocks don't fit on them! Maybe AE has another stiffer spring for them but, I just put them on my Stampede! They are just too weak for the weight of a Maxx!
WY
You can use the stock tmaxx upper spring retainers over the ae spring retainers they slide right on, them put some stock tmaxx lower spring retainers on. This way you can use any spring that will fit on the Stock shocks or big bore shocks!! Ive got some pix I think if yould like to see what they look like!!
