Hesitation going into 2nd gear...
Hey guys,
When I give my mini mgt 3.0 full throttle it hesitates/bogs after going into second gear. I tried richening the mixture but the car wouldnt hold an idle. Any suggestions?
My Feedback: (31)
KY
RE: Hesitation going into 2nd gear...
You need to richen your High Speed Needle, and probably Lean your Low Speed Needle by the sounds of it. Richen the HSN until the truck runs like it should through the gears, and then go back and either lean the LSN or raise your idle some so that it will stay running, and have good performance off the line. That should get you fixed up.
