dirty tanks
CA, AMERICAN SAMOA (USA)
dirty tanks
hey i was wondering how you guys wash your tanksand your trucks???
do you guys use dish soap and water?? or them pricey cleaners you get from your LHS??
now i know youre suppose to watchout for the electronics...so i stay away from them with the water...but is there other options?? ihear simple green...i evenhear of brake cleaner...is that true???
let me know...thnks!-Chris
ON, CANADA
RE: dirty tanks
When I tear down my truck I put all the parts in dish soap and hot water. I use a small scrub brush. When I was the tank I dry it off and leave it to dry for a while.
RE: dirty tanks
I get the worst dirt off with Simple Green, let it soak a bit, then blow it off with compressed air....I've found Simple Green works better than nitro "cleaner"....The Team Orion stuff I bough sucks.....and at $9 a can I can buy 3 big refill bottles of SG....
RE: dirty tanks
The Odonal (pink cleaner) works really well and you dont use near as much.
As for the fuel tank and engines I use CRC Brake Clean you can get it from wall mart. Just make sure you take the o ring off the tank lid as it will cause it to swell up. I use the straw and spray it in from the fuel outlet. That way it back flows the stone or sintered metal filter in the tank.
