Alum. knuckles breaking my wheels
Hi, i got a problem with the aluminum knuckles chipping off the inside plastic spokes on my wheels. 2 already cracked through.
I was wondering if i should get alum. wheels or put the plastic knuckles back on to fix this problem.
Anyone have this trouble before let me know what you did.
WY
Umm it has nothing to do with your knuckles, its a sure sign that you need to CHANGE THE WHEEL BEARINGS, and or replace the wheels hexs!! Ive been down that road!!
Here is what i need:
http://rpmrcproducts.com/products/tr...s/Knuckles.htm
Stepped front surface to prevent plastic wheels from hitting the axle carrier under high cornering & jumping loads.
The stock Tmaxx wheels are holding up quite well though with only a slight chipping on the spokes.
Anyone have the proline velocity wheels (white/yellow dish) I was curious what the inside of the wheel looks like and how strong it is reinforced. Also if it could handle the weight. (all alum)
Originally posted by packerfan3001
get new baeraings or just try to shim your wheels out a little
WY
Originally posted by lamp3y3
what are baeraings? lol... i have new bearings and btw what difference would that make? they dont change the clearance any. I did tighten my front knuckles a little more which helps
-new bearings
-new plastic or aluminum wheel hex's
-or 6mmx8mm shimms to go in fornt of pins that the hexs slide on!! This is the only way to extend the wheels from the knuckles without going to offset hex's!!
