ughh!!!! Melted T-Maxx
I found these pics of a rocket powered t max. it used 5 rocket engines, but on this particular run, only one fired corectly. The other 4 fired backwards. Figure the rest out from the pics.
That stuff is pretty old. He did that a looooong time ago! But still, it's pretty cool. You should have seen the vid!
By the way, I forget what site that was from. Can you give the url to me?
there are vids on the site........
but the comp with the URL on it is decided to missbehave......big time. Ill try and find the link
Originally posted by Flying Monkey
a few more. action shots
LMAO look at the smoke trail LMAO thats one of the funniest things i've seen in a long time
bet he was ****ting himself when it didnt gain any speed and smoke started pouring out from inside the car!! wonder if the smoke chocked the car or if it was the heat would make that engine stall
LMAO ...ok so let me get this staright..he put the rocket engines in backwards and lol... set them off and just let his truck burn?Why didn't he try to put it out?
I actually went to the URL that was provided, read the page, and watched the videos. The truck was indeed running when he fired the engine. He only had one fire because the 9 volt batteries he was using to fire the ignitors wouldn't do all 6 rocket engines. At the end of the burn, the single engine ignited the other 5 unused engines from the wrong end, making them fire out the top (front) instead of the bottom (back). Why didn't he try to put out the fire? You cannot extinguish solid rocket boosters once they have started. The solid chemical fuel they have contains it's own oxygen component. You can even submerge it in water and it will still run until it uses up all its fuel.
Jeez that looks hilarious!! I think I'll try that when I get my next TXT-1 arrives!! (LRP ESC, 2x 12-Turn Trinity Speed Gem Motors, its insane!!)
Well, I gues this video is coming from guys who do this on purpose !! The mess up rides and make vid's of it and sell them for big money. No one is this stupid to do this unless he's a real *sshole.
