E-Maxx breakable parts?
Does anyone know what are the most breakable parts on a new e-maxx? :confused: Because i would want to buy extra parts, if needed.
Thanks a bunch, Dirtbikedrew |
Re: E-Maxx breakable parts?
Originally posted by Dirtbikedrew Does anyone know what are the most breakable parts on a new e-maxx? :confused: Because i would want to buy extra parts, if needed. Thanks a bunch, Dirtbikedrew |
Tsk Tsk..
The most common parts you will break on a new emaxx will be the rear slider shafts, if you are doing alot of high traction running and doing wheelies you will twist the rear drive shafts!! You will also go through some turnbuckles as well if you run on carpet!! |
Originally posted by adeoliver Tsk Tsk.. The most common parts you will break on a new emaxx will be the rear slider shafts, if you are doing alot of high traction running and doing wheelies you will twist the rear drive shafts!! You will also go through some turnbuckles as well if you run on carpet!! |
Definatly the drive shafts and body posts get rpm there strong and cheap
| All times are GMT -8. The time now is 08:27 PM. |
