neubie need engine size explanations
is there a chart explaining all this?
ok lets see
.12 to .26 engines are usually used for nitro cars and trucks .12 way up to 3 can be used for airplanes .30 to .90 engines are for helicopters now as far how much horse power a engine procuce depends on a lot of things first is manufaturer...You can buy an high quality .21 engine that will beat the crap out of a cheap .26 engine.... you would have to be more specific on what information you are looking for... |
OK what is the relationship between engine sizes(.26) and cubic centimeters
what is the cut off between smallblock and bigblock? like a small block 400 chevy and a 402 bigblock chevy are the same CI but have way different torque #'s and size difference. A new 2.5 t-rex monster truck is still a small bolck? are engines with high HP numbers and small displacement a problem to "putt" around with cause of no power at low RPM? like a .21 is really 3.5CC? what does the .21 stand for? |
Ok simply put
.12 or .21 or .15 or anything you see in a car or truck in this range is referring to cubic inches. a .15 ci engine is approximately 2.5 cc a .21 ci engine is approximately 3.5 cc a small block is anything that is physically based off of a .12 ci block, typically all of your 1/10 scale stuff. They make them up to about .18 ci, I think. A big block is anything based off of a .21 ci block, typically any 1/8 scale stuff. I think they are making big blocks up to .27 inches now. It is similar to Chevy having the small block and big block, but a little different. If you are going to get into any serious racing and plan to go to any ROAR events, stay with either a .12 or .21 depending on your racing class. If you are just messing around, get the biggest and most powerful your wallet and truck can handle :) Sean |
Ok I understand.
next question; the glow plug, used to start the engine. Does it serve a function after the engine is running? it must or these would be called deisels LOL! btw I bought a CEN mt-2 last night for 260. |
Correct, there is a catalytic reaction between the alcohol in the fuel and the platinum (i think) in the coil that keeps it hot while the engine is running. If you "loose" your plug, your engine stops running.
Sean |
so if .15 is really 2.5 cc and so on. what would the TRX 2.5 be????
Thanks, Larry |
a .15
traxxas just used that number to make it sound big. dont get it. the engine sucks. it is great for 2 gallons and its downhill from there. in the tmaxx it is way overstressed from the weight and stuff. it is great for the other traxxas cars though, as from what i understand. soon im going to be dropping in a .18 sirio or a big block conversion chassis. i cant decide though. the big block will cost nearly $650 when everything in the drivetrain is bulletproof.... oook straying off topic. anyways, hp really means nothing in rc. its more of the torque curve yous hould be after. if the engine reaches its peak (1.6 lets say) horsepower at 35,000 rpms, then it will more than likely be horribly weak at moving a big vehicle since it would have no low rpm grunt. |
ok?... but if its the same...how come its so much faster?
also, do you have any proof about the 2 gallons then downhill (as in, did it only happen to you?) |
Originally posted by flatlander_14 a .15 traxxas just used that number to make it sound big. dont get it. |
Originally posted by halb0971 Correct, there is a catalytic reaction between the alcohol in the fuel and the platinum (i think) in the coil that keeps it hot while the engine is running. If you "loose" your plug, your engine stops running. Sean In order for our hobby fuel to combust, you need air, fuel, compression, and heat (supplied by the glow plug). When starting the engine, you preheat the glow plug by running current through it. When the engine fires, the heat from combustion also heats the glow plug (and keeps it hot enough for the fuel to burn next cycle). |
the fuel does have a reaction with the platinum plug element as well as retaning heat so you are both right.
Originally posted by RCFreakInFL No, it is called a 2.5, because a .15 is a 2.5cc motor. It was actually called the 2.5, to separate itself from the 1st series TRX 15's that were used in the 1st gen MAXX's, 4-tec's, and Nitro Rusty's....a 2.5 to me doesn't sound bigger than a .15, it sounds the same....because it is :) You have to admit, to an uneducated consumer, a 2.5 does sound like a larger engine than a .15. Does Traxxas actually market it because it sounds bigger? Only Traxxas can answer that. My personal opinion, yes, but that’s just my opinion. And, i8tweety, there is an reaction that occurs, I am sure the metal in the coil holds some heat, but is a reaction too. Sean |
If heat wasn't key, you wouldn't need a glow igniter. The metal composition has to do with it's ability to absorb and radiate heat (as well as longevity properties in the harsh environment in which it is subjected to).
If you take a new glow plug, while holding it upside down, take a thermal temp on it (I use my raytec temp gun). Measure the temp of some hobby fuel. They will both be at ambient temperature. Put a drop on the glow plug coil and measure the temperature every couple of seconds. You will find the temperature doesn't change. I don't buy into the chemical catylist theory. With respect to traxxas calling the new engine a 2.5, their previous generation engine (which they still sell) was called the traxxas .15 pro. In my opinion, they used it to differentiate between the two. |
Sorry to burst your bubble....
"Can you explain to me how a glow engine works? Is it just like a diesel truck engine? Glow engines are a hybrid between diesel and spark-ignition engines in regards to their mode of operation. In a glow engine, the catalytic action of the platinum glow plug coil is what ignites the fuel-air charge rather than a spark or the heat due to compression of the mixture in the chamber. As a consequence, the compression ratio used tends to be higher than in a spark-ignition engine but lower than a diesel engine. " This is right off of Super Tigers home page, if you do a little reseach you will find out everyone else will tell you the same thing, because its how our engines opperate. http://www.supertigre.com/faq/product-faq.html#q210 Sean |
ok?... but if its the same...how come its so much faster? that is a great website if you want to find out how a lot of this stuff works. also, do you have any proof about the 2 gallons then downhill (as in, did it only happen to you?) |
I was bursting i8tweety's who "I don't buy into the chemical catylist theory. " even though its how the engine works
Sean |
Originally posted by i8tweety With respect to traxxas calling the new engine a 2.5, their previous generation engine (which they still sell) was called the traxxas .15 pro. In my opinion, they used it to differentiate between the two. traxxas just used that number to make it sound big. dont get it." Whatever their marketing technique is, so be it....but it was called the TRX 2.5, more than likely to differentiate it from being the original TRX .15, which there is a HUGE difference between the 2 motors. I don't think it was a tactic or a ploy, to confuse the consumer....but the fact is, it is a VERY POWERFUL .15 motor anyway, much more than the majority of .15's out there. |
glow plugs
I'm glad to see you did your research with respect to glow plugs. As an engineer with a chemistry background, here's my explanation. Here's the quote you provided. I agree with everything it says. Glow engines are a hybrid between diesel and spark-ignition engines in regards to their mode of operation. In a glow engine, the catalytic action of the platinum glow plug coil is what ignites the fuel-air charge rather than a spark or the heat due to compression of the mixture in the chamber. As a consequence, the compression ratio used tends to be higher than in a spark-ignition engine but lower than a diesel engine. It does not refer to the platinum coil as a catalyst, but rather states the platinum coil provides a catalytic action. The catalytic action is the absorption and radiation of heat energy. Glow engines do not use spark ignition and do not use "heat due to compression", but use heat radiated from the glow plug's coil. |
the 2.5 may be a fast engine, but so many people have problems with it. i dont know a whole lot of people who have had their 2.5 for lets say 4 gallons and like it. as for the naming thing, maybe they didnt intend for that to happen, but it did. i remember reading a ton of posts a while ago. tons of new people to the sport had thought that it had 2.5hp and stuff along the lines of that.
I too am an engine FYI.
And if you read what I wrote, I never said the planinum coil was a catylist, I said "Correct, there is a catalytic reaction between the alcohol in the fuel and the platinum (i think) in the coil that keeps it hot while the engine is running. If you "loose" your plug, your engine stops running. Sean" it is a reaction between the methanol and the platinum, you can not run ethanol with a platinum glow plug and get the engine to run, you will need a spark ignition if ethanol is run. So yes I am saying the heat comes from the reaction between the methanol the platinum. Sean |
Originally posted by flatlander_14 the 2.5 may be a fast engine, but so many people have problems with it. It's a simple motor (to me), to tune, and I have never had any personal issues. There have been many "kids" at the track, who were fed up with thei 2.5's, telling me how much crap they were, and how they heard such bad things....they gave me 3 minutes with their motors, and they haven't had a complaint since! I wish I could have everybody on here send me their 2.5's, and for me to adjust them correctly, and send them back. I am noot preaching Traxxas, but preaching more the fact of the inexperienced level of knowledge, that are tuning these motors. I think to single out the 2.5 as a disaster, does not do the motor justice at all....I think it is an inaccurate assumption, which has lots of bandwagoners, who look to that excuse, as an excuse for their motors not running, than rather looking at themselves, for not knowing how to get it running.... |
I Agree
I agree with you RCFREAKINFL, I have been in RC for 10 years, and have had no problems with any of the 2.5's. They are a little harder to tune than the regular motors but it can easiley be done if you have the exp. with engines.
