RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   T - max reverse problems (https://www.rcuniverse.com/forum/rc-monster-trucks-160/1155211-t-max-reverse-problems.html)
T-man 09-22-2003 10:51 PM
Sometimes when I want to shift back and forth from forward an reverse it won't shift and gets stuck in that gear. Does anyone have any solutions?
evlwevl-RCU 09-22-2003 11:43 PM
RE: T - max reverse problems
Mine does that some times and its always associated with the idle being to high. Try lowering your idle and see if it engages, I'm assuming your reverse servo and tranny are in working order
Dlock 09-23-2003 01:13 AM
Be sure your idle is not set to high, like previously stated. Also you can move the collars that are on each side of the serve horn on the fwd/rvs linkage in some. Basically move them in towards the middle. This will give you more tension in those springs.....
