RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   Engine problems Help@ (https://www.rcuniverse.com/forum/rc-monster-trucks-160/1160111-engine-problems-help%40.html)
muddyrover 09-25-2003 12:51 AM
I was running my savage ss today and have had a slew of problems and thought that today I would get to enjoy my first run without any.
I was going and all of a sudden my engine cuts off. I try and crank it back up and when I put the roto on it, it just spins and doesn't turn the engine over. One way bearing I think. Not to bad, just another trip to the HS. I take it out take the roto backing off and take the one way off and try to turn the engine with just the shaft in the back and it won't turn over even when I am using the shaft to turn it over.
When I turn the flywheel the engine does turn over and the piston moves and all, its just that when I turn the shaft that starts the truck nothing happens.
I am baffled by this mystery please help.[sm=drowning.gif][sm=confused.gif]
muddyrover 09-25-2003 01:20 AM
RE: Engine problems Help@
it seems that my engine ate part number "1433".
My Starting pin/ pressure spring.
What is the cause of this?
