how do u lock ur diffs
i just got a txt-1
i want to crawl with it so i need to lock the diffs. how do u do it and are there some pics out there. and are there any other mods i need to do to get it to crawl better. philip |
RE: how do u lock ur diffs
temporary lock.
put "silly putty" in the diff. it will be *mostly* as effective as other methods but will be removable. to lock it forever put JB weld or similar in the diff... it will be locked solid with no slip... but it will be that way forever. clean the oil out of the diff and fill it with either compound and it will work. |
well just pore sum jb weld in don't use silly putty it regurly semi locks the diff and not fully also you could try car bumper repair stuff its a mix of two substances and i treid it in my 20" artucilation txt and it worked perfectly!!!!!!!
how did u get 20" out of ur txt
philip |
a kit called the excaliber it was £400 but well worth it it has two conrad 600bb motors which produce more than 6 times the toque of lrp truck pullers but the power is only 5w's but get 2 hr runtime!!!!!!!!! with two 3300 ni mh also it has imex jumbo wheels tyres and is unbelievable at rock crawling i have got some videos of it and will be posting them soon!!!!!!!!!!!
please do post those vids.
philip |
i will probarly in the next few days
in my 20" artucilation txt |
you can also use chunks of rubber band if its a bevel gear style diff. Planetary gears are hard to lock.
Use silicon diff lock oil. They are available from 1000wt to 120 000wt.
i tried that stuff and it doesnt work. i just bought an emaxx tranny and will be making the mounts this weekend. the stock tranny sucks and is to loud.
oh yeah it can cost me £400 though
| All times are GMT -8. The time now is 07:43 PM. |
