Help on Switching Gears
Ok i got a mad force today and i got it runnin and the first gear broke, so i was wonderin if i could (just for now) move the 2nd to 1st gear, and 3rd to 2nd gear. I know it will decrease the acceleration but will it work for now....
Thanks |
RE: Help on Switching Gears
REMEMBER...everything is possible, but you need to do some work, you need to take out the gears, open inside of the gears, and there should be a small clutch inside of the 2nd gear, you need to loosen the clutch spring a lil bit NOT completly, then point it out and sitck something in there so that it would stay sticking out, NOTE: it need to be soemthing that will stay there, because remember is gonna spin 25,000+ rpm, and it might fly out.
i hope you understand |
