16% Nitro For MGT TT21 engine, is it too low?
Hello People,
What % of nitro do you run with your TT21 engine? I have been using 16% nitro but the engine got a bit too hot last weekend. |
RE: 16% Nitro For MGT TT21 engine, is it too low?
i run 20% but i don't own a mgt.you should try 20% ti's pretty cheap i spend like 80 bucks on 4 gallons of red alert.it's good fuel better than traxxas definatley i hate traxxas fuel
Go with Duratrax O'donnel 20% or Trinity MH fuel, if your lhs stock's those. Sidewinder is also good stuff.
I've not had troubles with Dynamite BlueThunder 20% fuel in my road car or MT's. You may have troubles with idling using very low nitro content. Also, I think a higher nitro content actually cools the engine, but I've heard very valid arguments both for and against this so don't take my word as law on this.
My LHS said Sidewinder has gone out of business! The one they now stock is called "YORK" & I found no information about it on the net.
ORIGINAL: normanski My LHS said Sidewinder has gone out of business! The one they now stock is called "YORK" & I found no information about it on the net. |
In that case, may be Sidewinder is no longer available in Hong Kong then. Bad Luck for me!
Has any of you heard of YORK fuel? |
well i use 20% XTM nitro fuel, it really makes the engine more durabule and easy to tune, it even makes the engine run cool here in the HOT saudi arabia :D
TT 21 |
