LST Part Pricing
So far these are some of my upgrade plans for my future LST...If you can, please give me some canadian pricetags I can expect to see on these things, and Specificly what item I should get. (Example: What brand of Temp Gauge)
-Losi LST RTR: ($900.59 after tax) -Aluminum Dif case: ($20?) -Roll Bar (Curved U-Shaped bar in middle) -Threaded shock bodies: ($65/Set?) -Aluminum C-Hubs -Aluminum Secondary gear cover -Failsafe -Aluminum Arms -Aluminum Clutch shoes and 1.1 Clutch Spring -Yellow spring set -Platinum Spring Set (Tight silver springs) -Aluminum dif cups -Losi Titanium Turnbuckles -Spare CVD's -Onboard MIP Gauge -Losi Swaybars -Titanium Nitride Spur Gears. -New Break Pads -Losi High Capacity Gas Tank Thanks for your time. Mark |
RE: LST Part Pricing
1 Attachment(s)
Oh, While I remember... Does this roll cage get in the way of the gear cover?
Do what I do use this converter, http://www.fieba.net/index.htm
O-yea, Look on E-bay you can find Good Deals on NEW LST Parts or the Truck itself.(e-bay has Canadian prices) |
Cool, That'll Help!
Actually, I dont think That'll be accurate, the US prices are usually almost 2x as much.
ORIGINAL: Black_Ghost_FN Actually, I dont think That'll be accurate, the US prices are usually almost 2x as much. |
I know but when it comes to buying things. for axample, a nitro X-C is about $240 US, and twice as much Canadian. But when I cashed in the $30 US cheque, it only came to about $36 [:o]
And it was a $40 rebate from bestbuy so i got ripped off by $4.
Heres my list of my dream LST, Anything Else I should get? (The Prices and total are all VERY roughly estimated)
-Losi LST RTR: ($900.59) -Aluminum Dif case: ($20?) -Roll Cage Silver ($100?) -Threaded shock bodies: ($65/Set?) -Aluminum C-Hubs ($30?) -Aluminum Secondary gear cover: ($15?) -Failsafe: ($75?) -Aluminum Arms: ($240?) -Losi LST Adjustable Race Engagement Aluminum Clutch Shoes and 1.1 Clutch Spring: ($30?) -Yellow spring set: ($15?) -Platinum Spring Set: ($15?) -Aluminum dif cups: ($25?) -Losi Titanium Turnbuckles ($20?) -Spare CVD's -AA Batteries -Onboard MIP Gauge: ($40?) -Losi Swaybars: ($40?) -Titanium Nitride Spur Gears.: ($40?) -Fiberglass Brake Caliper Pads: ($10?) -Sidewinder 30% Fuel: ($43/Gallon) -Losi High Capacity Gas Tank: ($25?) -Aluminum Shock Towers: ($75?) -Aluminum Threaded Fuel Lines: ($25) -Aluminum Bulkhead: ($40?) -Fuel Bottle: ($10?) -Glow Plugs ($5-8) -Titanium Skids: ($50Each?) -New Era Wheelie Bar: ($50?) -Race Pro Cooling Head for Mach .26: ($100?) -LST Screw Kit: ($15?) Total Estimated at $2,100 |
I just did a currency conversion from US Dollars to Canadian Dollars for a LST costing $560.00 and the Canadian total came out to $692.17 as of today.
_____________________________ Check out www.killerhobbies.com. Monster trucks, parts, & accessories. |
Its more like 740-800 (790 at my LHS)
Did you include the outragous tax those too the North must pay? I paid $500 + 7.25% sales tax for my brand new at a local hobby shop, so deals can be had if you take the time too shop around. But those up north are getting ripped off. ORIGINAL: brushless I just did a currency conversion from US Dollars to Canadian Dollars for a LST costing $560.00 and the Canadian total came out to $692.17 as of today. _____________________________ Check out www.killerhobbies.com. Monster trucks, parts, & accessories. |
Nope. Didn't include that.
ORIGINAL: Black_Ghost_FN So far these are some of my upgrade plans for my future LST...If you can, please give me some canadian pricetags I can expect to see on these things, and Specificly what item I should get. (Example: What brand of Temp Gauge) -Losi LST RTR: ($900.59 after tax) -Aluminum Dif case: ($20?) -Roll Bar (Curved U-Shaped bar in middle) -Threaded shock bodies: ($65/Set?) -Aluminum C-Hubs -Aluminum Secondary gear cover -Failsafe -Aluminum Arms -Aluminum Clutch shoes and 1.1 Clutch Spring -Yellow spring set -Platinum Spring Set (Tight silver springs) -Aluminum dif cups -Losi Titanium Turnbuckles -Spare CVD's -Onboard MIP Gauge -Losi Swaybars -Titanium Nitride Spur Gears. -New Break Pads -Losi High Capacity Gas Tank Thanks for your time. Mark |
Yea I know, that was just a list of mostly possibilities that I may want later on, Its actually longer now! But Ill get what I need as I go, and RPM arms because theyre like 1/3 the price of alum. But I's d like aluminum C-carriers, hubs, and bulkhead, but thatll be quite alot right there.
Oh, its not just the taxes (14% total here) its that the products cost almost 2x as much even though the US to canadian conversion is much less. |
