help with fail safe
how do i center my throttle servo, i got the mammy back with the picco .27 and i noticed the hobby shop guy had my throttle trim all the way to the left. so that is actually giving me less throttle. i dont need it yet i am still breaking in the motor have not yet shifted to second. So how do i re center the throttle servo.
i also just got one of these http://cgi.ebay.com/VENOM-RACING-sma...QQcmdZViewItem Thanks |
RE: how do i re adjust me .....
problems with the failsafe, i have new batteries. but i can not figure out why the failsafe is engaged, i must have something set wrong. Anyone else have one of these fail safe units that can help me?
Thanks |
What type of battery are you using??
what reciever battery.? standard batteries 4 AA's. and the voltage cut off is set at 4.2 volt as suggested by the instructions.
AA 's don't work real good for RX's but with a full charge they should. I know this is way odvious but did you reset the failsafe? what brand is it venom ones die soon.
i still need help setting the unit!!
| All times are GMT -8. The time now is 08:30 AM. |
