RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   Warhead question (https://www.rcuniverse.com/forum/rc-monster-trucks-160/4497036-warhead-question.html)
kliney22 07-13-2006 11:09 AM
Warhead question
Hi all,
I just bought a new warhead and I cant get the idle top come down. the carb just wont close more than 1/4 of the way even after after adjusting the idle screw. when it starts it revs very high. nothing it worked fine when I first srarted it and I didnt get to finish breaking it in. and now I dont want run it anymore with the idle this high because it has not yet been broken in. any suggestions would be greatly appreciated
ThermalRD 07-13-2006 11:48 AM
RE: Warhead question
If your idle screw is turned down that far, and it still idles high, its likely a "lean" low speed needle setting. Richen that up a bit. See how the idle changes.
riffrafff 07-13-2006 12:58 PM
I'd pop off the linkage at the carb and see if the slide will close then. The idle stop screw should keep it open about 1.5mm. If that's okay, then it could be your linkage is out of adjustment. It might also occur if your carb slide is rotating. If the slide rotates, the stop screw is no longer in the groove. Normally this manifests itself by killing the engine when you apply the brakes. Slowly (!) turn the screw in (clockwise) while slightly rotating the slide back and forth until you find the groove, and set the opening to 1.5mm. Warm up the engine, set your high-speed needle. Then set the low-speed needle so it doesn't bog off the line, and use the pinch test. When the two needles are set, fine-adjust the idle stop screw.
Mine was running lean when my idle stop screw o-ring failed; but you could also have a air leak somewhere else, though that wouldn't hold your slide open like that.
I just reread your post...make sure your throttle adjust bias knob is correctly set on the transmitter, too! :) (Do that first!)
Oh, and welcome to rcuniverse!
edit: edited for speeling [X(]
kliney22 07-13-2006 01:20 PM
Thanks for fast replies I will try that tonight. Great site btw. I am fairly new to nitro cars & trucks
Steve
