RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   MGT Engine problem.. (https://www.rcuniverse.com/forum/rc-monster-trucks-160/4512218-mgt-engine-problem.html)
ICrashThings 07-17-2006 01:38 PM
So I got my new drill, new glow starter, new glow plug, fresh fuel, made sure everything was charged and ready. Ok great no work today!!!! yes! everything is perfect. I go outside and i try to start up the MGT with my new drill. Nothing. I try again, nothing! Arrrrgh. Im running the stock .21 engine, any ideas?? :[
blackrain 07-17-2006 01:45 PM
RE: MGT Engine problem..
you shore the drill is spinning in the right direction and check glow plug
ICrashThings 07-17-2006 02:07 PM
yes im sure the drill is spinning the right way lol. The glow plug is new and it still works. the other day it could atleast keep a tune, but now its not even starting. :\
jkrustchinsky 07-17-2006 02:27 PM
well whats happening when its spinng, is the engine turning over, if its not then you have a bad one way bearing, if its turning over then its a fuel/air problem,
Bria1 07-17-2006 04:26 PM
If it is turning the engine over, do you have fuel getting to the carb. Also, what rpm does your drill spin at?
duckedup 07-17-2006 09:26 PM
you could also check your glow plug, I've heard that if you run it out of fuel and let it die that way, it's not good for the plug
