RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   MGT Transmission problem??? (https://www.rcuniverse.com/forum/rc-monster-trucks-160/5749085-mgt-transmission-problem.html)
jonnymac 04-21-2007 01:42 PM
Hi Guys
The MGT Seems to be running fine except it will not stop. If you start the engine with the wheels off the deck it runs but the wheels turn. When you put it on the deck it stalls. I have tried adjusting the idle but it doesn't seem to work. The idle itself is not high. I would not expect the clutch to engage at those revs. Is there anything anybody knows about this? Even when I pull the starter the wheels turn.
Sound like a clutch problem???
Any ideas welcome
SOILWORK 04-21-2007 01:54 PM
RE: MGT Transmission problem???
It sounds like the clutch. One of the clutch spings could of broke.
-EXTRA- 04-21-2007 02:01 PM
Have you replaced anything in the clutch,clutch shoe's,spring's etc.,that's what it sound's like.
jonnymac 04-21-2007 02:28 PM
Not really though I put the clutch assembly onto another engine. I'll strip the engine out and take a look.
scottywilkes 04-21-2007 07:00 PM
def sounds like the clutch, if its idling normally, the power shouldnt even be getting to the tranny yet. My guess is maybe either the springs have lost there tension, 1 has snapped or the clutch shoes have melted to the clutch bell, check it out and post your findings
jonnymac 04-22-2007 04:35 AM
The springs and shoes were fine, it appears I managed to get some debris caught up inside the bell.
Seems to be fine now.
Cheers guys
