Shoping list!
Well as of now here is my shoping list hoping to find it on ebay cheap.
Pro-Line 40 Series Mambo Wheel 2.5 Maxx/Savage Pro-Line Maxx 40 Big Joe Tire T-Maxx E-Maxx (2) x2 MONSTER S-1600 W/STICK: (clear) LST/2/AFT - LOSB8021 I know they have major probs but some teflone will fix them Integy MSR6 Piggyback Shock Silver LST (4) or these Team Losi assembled shock with spring (1): LST2/AFT - LOSB2879 x4 Shock Spring, White 4.0 (pr): LST, LST2, AFT - LOSB2949 Maxamizer 14mm hex conversion Wat u think guys? |
RE: Shoping list!
Nobody, not even u chronic?
RE: Shoping list!
sounds good to me
RE: Shoping list!
looks good to me, which body r u gonna use on it?
RE: Shoping list!
I'm leaning toward the Baja beetle body that goes one the lst2
http://i52.photobucket.com/albums/g1...n/losb8021.jpg or the proline one http://i52.photobucket.com/albums/g1...an/Hb80818.jpg http://i52.photobucket.com/albums/g1...an/Qv55901.jpg They look so cool! |
RE: Shoping list!
definately the proline one!
RE: Shoping list!
ya i think i'm gonna go with that one or there is one more that is calling my name.
RE: Shoping list!
ORIGINAL: pythonfan ya i think i'm gonna go with that one or there is one more that is calling my name. |
RE: Shoping list!
It will actuly look good, the mad force is smaller then the lst/2 a savage body will work fine, oh and that other body is this one!
The specs are very close, Mad force * Length - 21.3" * Width - 16.3" * Height - 10.2" * Wheelbase - 12.4" * Track - 12.2" * Ground Clearance - 2" * Gear Ratio - 25.71 / 19.81 / 15.61 * Tires - 6.3" x 3.9" * Weight - 9.0 lbs * Engine - Kyosho GX21 Recoil * Price - approximately $379.99 Savage x ss 4.6 SPECS: Vehicle- Length: 21" (533mm) Width: 16.8" (427mm) Height: 10" (254mm) Wheelbase: 13.25" (336mm) wheels on-center front-to-rear This is the bronco body for savage http://i52.photobucket.com/albums/g1...n/DSC00883.jpg http://i52.photobucket.com/albums/g1...n/DSC00884.jpg But i want this! This was done by byte the dust http://image2.rcuniverse.com/forum/u...52/Ze87254.jpg http://image.rcuniverse.com/forum/up...52/Sd43133.jpg http://image.rcuniverse.com/forum/up...52/Kb45647.jpg http://image.rcuniverse.com/forum/up...52/Lj22821.jpg |
RE: Shoping list!
Yep, the Mad Force looks like a big truck because it sits pretty high and the chassis overhang and factory wheelie bar make it seem longer, but it's footprint is close to that of a Savage. All of those bodies would look good on it.
How much did you stretch the wheelbase? Use that to determine whether you use the Losi or Proline VW body. The Proline would probably look better on a stock Mad Force, but if you stretched the wheelbase an inch or more I would go with the Losi version. |
RE: Shoping list!
Well i did it by eye, wen i do the final, I'm doing it by measuring! Measure once cut twice:D
OK as u can see this is the new era chassis http://i52.photobucket.com/albums/g1...eaded_sh-2.jpg You can see the stock holes, then the first 25mm and then the next 25mm and the final 50mm, well its basically taking the chassis stock and moving it over half way left and right, that's Wat i did as u can see. http://i52.photobucket.com/albums/g1.../DCFC00382.jpg Nes stands for new era stretch, and FS is final setup! The hummer body said it was for the maxx/savage, but the body is 19-20inches long so i think it was for lst2, This is my body http://pro-lineracing.com/proline.html http://i52.photobucket.com/albums/g1...DCFC0042-1.jpg http://i52.photobucket.com/albums/g1...DCFC0043-1.jpg http://i52.photobucket.com/albums/g1...DCFC0045-1.jpg http://i52.photobucket.com/albums/g1...DCFC0044-1.jpg http://i52.photobucket.com/albums/g1...n/DCFC0046.jpg http://i52.photobucket.com/albums/g1...er_truck-1.jpg That body is this http://www.prolineracing.com/product...wproduct&id=92 |
| All times are GMT -8. The time now is 10:18 PM. |
