after run oil
how should the run oil be put in . any certain way or just pour/drops as you crank over engine.
thanks pirate man |
after run oil
If you have to ask a simple question as to,"...how should the run oil be put in..." eventhough the bottle has directions, maybe R/C nitro model cars are too complicated for you. Now I know why they still put directions on shampoo bottles and warn owners with hair dryers, "WARNING!! DO NOT USE WHILE IN THE SHOWER!"
after run oil
Although Krusty is correct..
You put a few drops through the hole where you slap the glow plug and a few drops through the carb.. Run the engine through a few compression cycles without a glow plug to coat all parts Thats it!! Please use the search function for elementary queries such as this.. I dont mean to be rude but its been asked WAY too many time!! Welcome to RCU btw! I know you will like it here! regards -ram |
