Where to put the Throttle return spring?
I have a spring I want to use as the throttle return spring but dont know where it goes. Does it go close to the servo (my guess) or closer to the throtle? Also there are already a few springs on the rod
Thanks Forcelite |
IT should come with a little eyelet..
Typically one end goes on the servo or the throttle and the other gets screwed down or gets attached to something that DOES NOT MOVE -ram |
| All times are GMT -8. The time now is 09:05 AM. |
