Where could I pick up..
Some silicone oil for my truck?
RE: Where could I pick up..
I'm supposed to get it for my Genesis GST 7.7. It says
Air Filter Oil After-Run Oil Whatever that means, and I read in the review that it's called silicone oil. Bear with me here, this is my first truck that's nitro powered. |
What type??? Shock, Diff?? Any hobby shop has it. I do most my shopping at tower hobbies since I dont have a hobby shop closer than 40 mile from me.
LHS
Tower hobbies - on line |
Shock, diff, whatever I'll need for a brand-new out of the box Genesis GST 7.7.
So, I can order it online at tower hobbies? |
ORIGINAL: PetrolisTasty I'm supposed to get it for my Genesis GST 7.7. It says Air Filter Oil After-Run Oil Whatever that means, and I read in the review that it's called silicone oil. Bear with me here, this is my first truck that's nitro powered. [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXL391&P=ML]After run oil[/link] [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDDN4&P=7]Air filter oil[/link] You can use after run oil or some including myself use WD-40 does the same thing. As for air filter oil this is what I use. you can use any brand you like. |
ORIGINAL: PetrolisTasty Shock, diff, whatever I'll need for a brand-new out of the box Genesis GST 7.7. So, I can order it online at tower hobbies? :D |
I searched through and I'm supposed to have... Urr, 20,000 weight oil. They have 10k and 30k. Does the difference really matter?
Oh, and, how much should I buy? I'll be taking this thing out pretty much all of the time it's not being repaired now that it's summer... So, I'll need enough for a while. What, like 3 bottles? |
Im kinda lost on this one. I figured the gst would already have shock oil in the shocks? For after run oil I buy the hobico brand, and for air filter oil I go to the local walmart and buy a huge compressed can of filter oil for foam filters and is water proof. Same stuff just alot cheaper for the amount you get.
