| DrFrunkenstein |
03-01-2003 11:45 PM |
jerky t-maxx Help!!
Perfectly normal. My T-Maxx did it all the time, unless you peg the gas right off the line that is ;). It's because there are two (three if you count the clutch bell and shoes) centrifigul clutches, and at low rpm, I guess it's hard for both of them to get enough RPM to engage at the same time, so it will stutter off the line until you get going at about 2-3MPH. If you put a reverse lock out kit, I hear it solves that problem (takes one of the clutches out). But, it isn't a bad problem, and it will never hurt anything. So if you like reverse, and can live with it clanking off the line, I say leave reverse in ;) Hope this helps.
