RCU Forums
-   RC Monster Trucks (https://www.rcuniverse.com/forum/rc-monster-trucks-160/)
-   -   mad force engine mount (https://www.rcuniverse.com/forum/rc-monster-trucks-160/6855244-mad-force-engine-mount.html)
alwmckay 01-04-2008 09:15 PM
Does anybody know if this mount- http://www.neweramodels.com/item.cgi...u&part_id=1503
will fit a force .21 engine and work on the mad force? I can't seem to find much info on it. Any help would be appreciated. Thanks
pythonfan 01-04-2008 09:47 PM
RE: mad force engine mount
ORIGINAL: alwmckay
i'm not sure about that mount i know other have used it, welcome to the forums, and glad to see another mad force owner here.
are you talking about the stock kyosho force .21 or the ofna force .21? if its the ofna then yes that mount will work, but kyosho also has there own mount to mount any upgrade motor to stock, but you going to need a few other things tho, here's a online web manual and a list of what you need.
http://rcdocuments.com/Kyosho%20MAD%...E%20Manual.pdf
http://rcdocuments.com/Kyosho%20MAD%...ded%20View.pdf
[link=http://www.ultimatehobbies.com/istar.asp?a=6&id=KYOMAW007!1012]MAW007 ENGINE MOUNT OS21RG[/link]
[link=http://www.ultimatehobbies.com/istar.asp?a=6&id=KYOMAW008!1012]MAW008 BELL GUIDE P SHAFT[/link]
[link=http://www.ultimatehobbies.com/istar.asp?a=6&id=KYOIF023!1012]F023 FLYWHEEL I5[/link]
[link=http://www.ultimatehobbies.com/istar.asp?a=6&id=KYOIFW54!1012]IFW54 FLYWHEEL NUT 3PC MP-6[/link]
Your choice of shoes and spring(s)
alwmckay 01-04-2008 10:34 PM
1 Attachment(s)
I dont know which it is, maybe you can tell me. Thanks for the info though. My computer wont let me download the manuals, so i will fix that later. Is there any tracks around Inverness? Here are some pics of the engine.
The Winner 01-06-2008 03:51 PM
welcome alwmckay! wow another mad force owner here! i have mad force too! so you want to put this blue ofne to your mad force?as i can see is very old and i dont now if the kyosho or new era mounts are a stright fit! but all guys(wuth mad force) when they change engine use or the new era or kyosho mounts and they are the same in dimensions! if you want to help me just take the length of the engnine ''ears''(ears are these metals with the two holes that go at the top of the mounts) take the length between the two holes of each ears and the length between the two ears! if the engine has the same dimension in ears as all new big block engine it will fit at mad foce! and as i can see you have a sg shaft and you have the flywheel and the nut so you want only the mounts and a bevel guide! for more infos check also : www.kyoshomonster.com i am a membere in this url!
The Winner 01-06-2008 03:59 PM
finally i belive that this engine fit and at the new era mounts and at the kyosho mounts!
